Aficio 2090 can't print ps file
  • joher
    • 43
    aficio 2090 can't print ps file even ps fount him self file, and error show in error log error 91 and pcl printing working properly,
  • KopyKat
    Nurse Ratched of Repair
    • Nov 2008
    • 366
    Do you have the PostSript SD Card Option installed and is it the correct one for that model? Easy way to find out is to print a Config Page for the printer, in the top section you will see the versions of PCL, RPCS and PostScript if it is there. If it does not list PS then it wont print PS.
    If it is there, you may need to upgrade the Printer PS firmware.
    sigpic
    Relax! This firmware injection won't hurt...but it will take 45 minutes.
    • joher
      • 43
      yes ps option is instaled and show on configaration page ps3 ver is (1.3) i have 5 ps card all card behave same problum and print error lag genrate a errer 91 code
      • KopyKat
        • Nov 2008
        • 366
        The current version for PS firmware is 1.04. I'd update all the firmware.
        And make sure you have the PostScript3 Unit Type 2105 and the latest PS print driver installed.
        If you have an SR90 Booklet finisher you need the updated firmware.
        Fixed: When the Plockmatic finisher (SR90) is connected, PS jobs are not printed at all.
        sigpic
        • joher
          • 43
          thankx i solve the problun its finisher problum,,,
          pleas healp me what is the procdure uplod new font in ps card
          • KopyKat
            • Nov 2008
            • 366
            log into the ricoh tech support site and download all the current firmware. Extract the files to an SD card in folder romdata/B070/
            After that follow the instructions in Section 5.10 Firmware Update of the Service Manual exactly.
            sigpic
