aficio 2090 can't print ps file even ps fount him self file, and error show in error log error 91 and pcl printing working properly,
Aficio 2090 can't print ps file
Do you have the PostSript SD Card Option installed and is it the correct one for that model? Easy way to find out is to print a Config Page for the printer, in the top section you will see the versions of PCL, RPCS and PostScript if it is there. If it does not list PS then it wont print PS.
If it is there, you may need to upgrade the Printer PS firmware.sigpic
Relax! This firmware injection won't hurt...but it will take 45 minutes.
The current version for PS firmware is 1.04. I'd update all the firmware.
And make sure you have the PostScript3 Unit Type 2105 and the latest PS print driver installed.
If you have an SR90 Booklet finisher you need the updated firmware.
Fixed: When the Plockmatic finisher (SR90) is connected, PS jobs are not printed at all.sigpic
log into the ricoh tech support site and download all the current firmware. Extract the files to an SD card in folder romdata/B070/
After that follow the instructions in Section 5.10 Firmware Update of the Service Manual exactly.sigpic
