mp6000 SD authentication error
  • RicohTech_TurksCaicos
    • Aug 2008
    • 55
    A co worker of mine has a problem with a MP6000 throwing SD CARD AUTHENTICATION ERROR. Anyone know a fix for this? He has tried taking the sd card from another machine and same results.
    SC866 SD card authentication
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    I couldn't find a RTB for SC866 for this model, but there is a RTB for SC866 for the MPC6000.
    That one is down to a system firmware bug.
    SYMPTOM
    SC866 (SD Card Error 1: Confirmation) occurs when installing an SD card option if the
    System/Copy firmware is older than Ver1.05.
    CAUSE
    Due to a firmware bug (System/Copy), the machine cannot authenticate the SD card.
    Note: There is nothing wrong with the SD card or application itself. The problem is with
    the System/Copy firmware.
    I would try upgrading or downgrading the system firmware for your model based on that info.
    • Canadian Tech
      Too Long in this field
      • 32
      Yup, Cipher is correct, there is a firmware fix for this problem.
      Most of the time the operators need fixing, not the machine !!!
      • stephend
        Senior Technician
        • 306
        Try the newest firmware version: Engine v1.034, System v3.02, etc. if your machine will be able to boot.
        Check the original card from this "sick machine" in a different unit to see if it's working. If it's working, disconnect HDD and try again. Next replace the memory....and last controller.
          • Aug 2008
          • 55
          From my understanding the problem has been fixed and he ended up replacing the sd card and the hdd and the problem disapeared. I did tell him about the Firmware
          • unisys12
            • 490
            Had one of these kick my tail all over the shop for the last two days. Replacing the HDD fixed it. I updated all firmware before this, but it didn't help.
            sigpic
            The first law states that energy is conserved: The change in the internal energy is equal to the amount added by heating minus the amount lost by doing work on the environment.
