MP 3350 Noise
  • Ltd
    • 90
    MP 3350 Noise
    I had a MP.3350 making vibration noise when the making copy, the sound came from right side, either fuser area or other place I am not sure. Someone kwow where it is ?
  • TonerMunkeh
    Professional Moron
    • 3865
    If it's an itermittent clicky rumble, kind of like a slow fart in a bathtub then it's the fuser. Just strip it down, clean and grease the bearings and bushings, hey presto.
    Hit it.
    • totoro
      • 568
      Take off the rhs cover and see if the noise goes away. I have had a few with this cover warped and had to put some rubber shims under it to make the noise go away. Good luck.
      Totoro
      • Ltd
        • 90
        What is rhs cover ?
        • syamrock33
          rhs is right hand side...
          i think u should do the output check....
          if it is not fusing unit..then open up back cover and see which part is turning when the noise happen
          • TonerMunkeh
            Professional Moron
            • 3865
            Don't forget on the Russian C5 the entire side door opens up like the Apollon, Athena and Alex. There is no interchange cover. One thing I forgot to mention too, the exit / interchange unit, toner can build up on the little white rollers in there causing an annoying noise too. Run the fusing / exit motor in output modes without the fuser in, you might get a couple of SC's but it will still run.
            Hit it.
            • Ltd
              • 90
              I don't see Fuser motor output check in Sp.5804. just M.motor or Bridge motor, Feed motor. I had test these but they don't generate vibration noise.
              • buttalasso
                I red in an OLD THREAD that the trouble could be the hot roller strippers; I tried to clean these pieces on a MP2000 and the rumour gone away.
                • Ltd
                  • 90
                  No, the MP.3350 is bigger, fuser is different than MP2000. The noise I talked about was vibration noise , not squeky noise like Mp2000.
                  • KopyKat
                    Nurse Ratched of Repair
                    • Nov 2008
                    • 366
                    I hate to bump up old posts but does anyone know what the final solution was?
                    sigpic
                    Relax! This firmware injection won't hurt...but it will take 45 minutes.
