savin 9965dp
  • T911
    • Jun 2007
    • 628
    savin 9965dp
    after the 8th copy consistantly it will jam in the finisher, not crashing just stopping. I removed the finisher from the machine tested all paper trays and it works fine. i can pump the machine with no jamming. i attach the finisher again and it does the same for all sizes. went back with some sensors and the pcbs for the finisher but no luck. (it's an sr730) ideas appreciated. thanks t
  • kayjaig
    • 144
    check finisher entrance sensor
    check finisher entrance sensor, the mounting bracket is easy to bent out of way.
    • schooltech
      School District Tech
      • Jun 2008
      • 504
      Have you identified exactly what jam code is being displayed? This could give you some idea of at least what sensor(s) the machine thinks is not operating properly.
      Bachelor of Science in Information Technology, Comptia A+, Comptia Network+
