Savin C3528
  • Vesigoth
    • Mar 2008
    • 133
    Savin C3528
    One of my techs did a memory clear on this machine and now the color registration is off and we can't seem to get it back. Every time that we try to do a color registration adjustment it fails. If you can help with this please respond.
  • unisys12
    • 489
    Oh man! You will need to check the Troubleshooting or it might even be in the manual. There is a manual Line Position Adustment Procedure that you have go through. Get it as close as you can, then rerun the Color Reg Adjust from user tools or SP's. If the auto adjustment fails, then your manual adjustments are still too far off. Run back throught whole manual process, try the auto process again. Once it passes, you should me good.
    You can get this back... I know because messed one up about a year ago (samething as your tech) and I performed the procedure another machine for our other office that they messed up. You just need to be patient, have a magnifing glass, don't let anyone rush you through it.
    Best of luck!
    sigpic
    The first law states that energy is conserved: The change in the internal energy is equal to the amount added by heating minus the amount lost by doing work on the environment.
    • FRIDGEMAGNET
      • Aug 2007
      • 377
      There should also be a factory data sheet under the jam removal decal inside the front cover.
      You can start by in-putting all these settings and then run line position adjustment in SP.
      If the sheet is missing.........
      Good luck.
      • Vesigoth
        • Mar 2008
        • 133
        Savin C3528
        Thanks guys. It took all day, but got it done. Thanks again for the help.
