2232c grinding noise from trans unit
  • ash_572
    • Oct 2008
    • 523
    i can actually see the gears on the trans cleaing unit struggling to turn when its making the screeching noise. transfer unit works fine when u remove the cleaning unit. cleaned the gears on both unit. works fine for a few days and then back to normal again.
    replaced the trans unit with the cleaning and still the same.
    what can it be?
    trans unit is seated correctly.
  • Froota
    Field service tech.
    • 129
    what can it be?
    Hey,
    I also had a problem like this one but on a 3245C, a bit the same machine.
    My solution was to swap the gears with those from the old unit. I guess there are 2 gears on the back of the unit, and one of them is too short and slips.
    Try it with a cleaning unit from a af3245. I think only the cleaning blade is different.
    hope it works.
    gr,
    Froota
    • E Winter
      Oh, nono
      I did this accidently and a few days later a work mate was very pissed on me because he had to vac the inside of the machine. The wrong unit does "fit" without any problems but there seem to be some differences with the waste toner nozzle or something like that.
      @ash:
      Maybe the transfer/cleaning unit isn't the problem. You should try to check all drives with the output check.
      • Ricohlovers
        • May 2009
        • 59
        2232 Noise from trans unit
        Hi All,
        Aficio3245C transfer unit comes with a coating bar. And the part no. for cleaning blade, spring blade, bushing and for the gear 23Z is different.
        Regards,
        • Ricohlovers
          • May 2009
          • 59
          Check the part numbers.
          B147/B149/B190 53 Parts Location and List
          1 G080 3830 Cleaning Unit:Transfer Belt:Ass'y 1
          2 G080 3732 Shield:Cleaning Unit 2
          3 G080 3731 Case:Coating Bar 1
          4 G080 3733 Dual Faces Tepe:Entrance Seal 1
          5 AD04 7034 Entrance Seal:Cleaning 1
          6 AD04 2047 Brush Roller:Cleaning 1
          7 AD04 1081 Cleaning Blade:Ass'y 1
          8 G080 3716 Bracket:Cleaning Blade:Ass'y 1
          9 AA06 0920 Spring:Blade 1
          10 AB01 1480 Gear:Brush Roller:Front 1
          11 AB01 1481 Gear:Idler:Cleaning Unit 1
          12 G060 3977 Gear - Transport Screw 1
          13 G080 3745 Lever:Release:Cleaning Blade 1
          14 G080 3740 Holder:Brush Roller:Front:Ass'y 1
          15 AD04 3081 Toner Collection Coil:Cleaning 1
          16 G060 3953 Sleeve:Shaft:Toner Collection Coil 1
          17 G080 3831 Casing:Cleaning Unit:Ass'y 1
          18 G060 3952 Shaft:Toner Collection Coil 1
          19 AA08 0248 Bushing - 6mm 1
          20 AB01 0126 Gear - 28Z 1
          21 B101 3810 Transfer Unit:Ass'y 1
          22 G080 3993 Lever:Release 1
          23 G080 3994 Cover:Transfer Unit 1
          24 5214 4975 Decal - High Voltage 1
          25 G080 3980 Stepper Motor:Transfer Belt:Press Fit 1
          26 G080 3990 Drum Stay:Transfer Unit:Peen 1
          101 0451 3006B Tapping Screw - M3x6
          102 0804 6075 Hexagonal Bolt - M3x8
          103 0451 3008B Tapping Screw - M3x8
          104 0451 3008H Tapping Screw - M3x8
          105 0450 3008B Tapping Screw - M3x8
          106 1105 0511 Harness Clamp - LWS-0306ZC
          107 0720 0040E Retaining Ring - M4
          Part No. Assembly Index
          No.
          22.Transfer Unit 1 (B147/B149/B190)C2232
          B202/B178/B180 53 Parts Location and List
          1 B242 3830 Cleaning Unit:Transfer Belt:Ass'y [TSB#035] 1
          6 AD04 2047 Brush Roller:Cleaning [TSB#035] 1
          7 AD04 2091 Cleaning Blade:Ass'y [TSB#035] 1
          9 AA06 1008 Spring:Blade [TSB#035] 1
          17 G080 3831 Casing:Cleaning Unit:Ass'y [TSB#035] 1
          19 AA08 0285 Bushing:MM6 1
          20 GB01 0016 Gear - 23Z 1
          21 B180 3810 Transfer Unit:Ass'y 1
          25 G107 3980 Stepper Motor:Transfer Belt:Press Fit 1
          27 B180 3734 Terminal:Brush Roller:Ass'y 1
          [TSB#035] 1
          29 AA06 3649 Compression Spring-Driven Roller [TSB#035] 1
          101 0451 3006N Tapping Screw - 3x6
          102 0804 6123 Hexagonal Bolt: W/Washer - M3x8
          103 0451 3008N Tapping Screw - M3x8
          104 0720 0040E Retaining Ring - M4
          105 0450 3008N Tapping Screw - M3x8
          No.
          22.Transfer Unit 1 (B202/B178/B180) C3245
          • jarhead2020
            • 34
            This noise can be a pain to fix not to mention cause banding when doing color copies. I have had to replace the motor inside the unit along with the belt that goes to it. In addition with one case one of the shafts in the T-unit was worn on the end so it put too much drag on the motor. It sucks but I would pull out all shafts on the unit and check them then put some oil on them along with replacing those two parts.
            • ash_572
              • Oct 2008
              • 523
              still cant get to the bottom of this problem. seems like theres loads of possibilities.
              • Polo-022
                • Sep 2007
                • 486
                Is there any-black-toner on transfer unit gears teeth? If you vacuum there, does this fix the grinding noise?
                • Shadow1
                  • Sep 2008
                  • 1642
                  I had a similar problem recently - ended up being 2 bad ITB blades in a row. I put a whole cleaning assy in because I figured it would be built with parts from a different lot.
                  73 DE W5SSJ
                  • ash_572
                    • Oct 2008
                    • 523
                    yes it does but then after abit it returns
                    • bryand
                      • Jul 2008
                      • 92
                      I remember having these noises on the CL7000 printers. The cleaning unit would warp and rub on the tension roller on the underside of the belt assembly. We had to scrape the front right edge of the cleaning unit with the backside of an exacto blade to eliminate the rubbing.
                      • Polo-022
                        • Sep 2007
                        • 486
                        Look at spare parts : '20.Toner Supply Section' part number 14. Maybe you have vacuumed away a small transparent seal (p.n 15) and it scatters toner all around...
                        Otherwise put a lot of dusting powder on trns. blade to check if that is the cause for grinding. Good luck!
                        • Fearless V K
                          • 620
                          I have had some success with slightly reducing the spring tension on the ITB cleaning blade.
                          Don't take that toner with me!
                          • ash_572
                            • Oct 2008
                            • 523
                            • ash_572
                              • Oct 2008
                              • 523
                              it runs fine without the cleaning unit. wen i fit the cleanng unit back in u can see the gears at the front f the cleaning unit struggling to turn.
