aficio 1045-problem in copy mode
  • romnick
    • Aug 2008
    • 56
    hello friends,please help. i have aficio 1045,it is giving a copy with a dark background in copy mode but in printer mode copy is ok. did you encontered already this kind of problem? please help. thanks in advance.
  • Fearless V K
    • 620
    Try lifting up on the front left corner of the scanner.
    Don't take that toner with me!
    • Vulkor
      • Jun 2009
      • 946
      YES, push up the scanner assembly while making a copy. Savin Acknowledges the 2535/2545 has this issue. Customer puts too much weight on console and it makes the scanner assembly tilt thus causing dark or black streaks on copies. The 4035/4045 also has this problem, but Savin won't admit to it.
      If that doesn't work maybe an SBU problem?
      • SGT_Snacks-64
        • Oct 2007
        • 157
        Might be something as simple as VERY dusty optics? :\
        Intel Core 2 Quad Q6600 2.4GHz (Oc'ed to 3GHz - Stock Volts)
        Asus P5E-VM HDMI
        4GB (2x 2GB) Corsair XMS Xpert II RAM
        ATi Radeon 4870 512MB GFX Card
        2x 74GB WD Raptor Sata HDD (RAID 0)
        500GB Seagate Barracuda Sata II HDD
        500GB Hitachi Sata II HDD
        600W500att OCZ PSU
        -TOTAL HDD SPACE 1148GB-
        • Jomama46
          • 2900
          Clean the optics first
          sigpic
          A+; Network +; PDI+
          • Vulkor
            • Jun 2009
            • 946
            Yeah would hope you've cleaned optics/dusted first. Standard Maintenance.
            • iMind
              Vacuum Cleaning Expert
              • Mar 2008
              • 1116
              Sorry to say, but dirty optics will give you light copies not dark, dirty optics will give you dark copies if the machine is analog, not digital, just my two cents.
              • Jomama46
                • 2900
                I too, am sorry you said that. Dirty optics will still cause dark copies. Dirt is still dirt and digital or analog cant tell the difference between a film on scan glass or a gray original.
                Light copies can be caused by a dirty laser scan glass.
                sigpic
                A+; Network +; PDI+
                • iMind
                  • Mar 2008
                  • 1116
                  • tcs04
                    FORMER Techie
                    • 1183
                    I'm with you!! dust = pale copies!
                    Best check for the problem on this machine is take one copy from the glass and one using the ADF. If the ADF copy has the background it's the scanner frame bent!
                    To tes, just lift the corner of the scanner and take an ADF copy while lifting. The new copy shold be OK.
                    To cure, "Reform" the frame! lift and release until the gap between the left frame and the edge of the ADF is uniform from front to back.
                    There was a bracket available which could be screwed to the left frame of the scanner to prevent this problem!
                    • Jomama46
                      • 2900
                      ehhhhhh! Wrong!
                      Loosen the screws on the left rear frame, raise the left front corner and tighten the screws
                      sigpic
                      A+; Network +; PDI+
                      • iMind
                        • Mar 2008
                        • 1116
                        • romnick
                          • Aug 2008
                          • 56
                          i make copy from both glass and adf on A4 but the problem is the same dark copy with white lines against the direction of paper,but if i tried to
                          print total counter copy is great-its ok,i planning to change ccd,what do you think?
                          • tcs04
                            FORMER Techie
                            • 1183
                            ehhhhhh! Wrong!
                            Will not cure a bent frame!!!
                            • Jomama46
                              • 2900
                              True, but most often I have found that the frame is not bent but sagging from the weight of users leaning on it.
                              sigpic
                              A+; Network +; PDI+
