ehhhhhhh! NOT wrong!!!!!!!!!!!
See attached. (Raised for paralleogram image, bur caused the PCQ problem due to the ADF not being close enough to the slit glass)
".......... An excessive load has been applied to the Scanner Stand, cauising it to bend"
Hence the increased thickness of the modified Guide Plate (item 27) and the extra Support Bracket to prevent the Guide Plate bending at the mounting point (Force x Distance... Isaac Newton was correct!)
