ricoh mp c6000
  • stavrator
    • Aug 2025
    ricoh mp c6000
    Hello everyone,
    I just joined this forum (although i have been reading it a lot) as i have a problem that seems noone can solve till now....hehehe
    We have an MPC6000 installed which is quite new (100k colour 36k black).
    All of a sudden the printing is a mess....Printing in colour makes the letters's edges look CMYK, meaning that i get an offset of each colour used by almost 0,001m. It wasn't doing that earlier, although the same file is used from the computer using the same software(PDF-MS Word).
    This problem gets even worse when using heavier paper.Would there be any suggestions to this?
  • pspahr
    Toner Schlep
    • May 2008
    • 227
    Funny thing---I'm in that class as we speak. I'll ask and see what we can find.....
    VectorLinux---Check it out!
    • pspahr
      Toner Schlep
      • May 2008
      • 227
      Stavrator---Could you scan in an image for us to look at?
      • stavrator
        here is a scanned print
        here is a scanned print of a printed envelope. It is supposed to be green-like letters.The file was created using the latest CorelDraw. Sorry for my late reply, but i was out of towna nd could not get the scan to send.
        Thank you in advance.
        • Herrmann
          • Jan 2006
          • 792
          at first try sp2-111 (forced line position adjustment)
          second: look for a slipping transfer belt
          If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
          • stavrator
            thank u
            thank you for your reply
            i will try these and let u know if it worked....
            is the transfer belt anyhow related to the media thickness??
            • Herrmann
              • Jan 2006
              • 792
              The maschine and therefore the belt speed ist related to the media thickness.
              I have seen such behavior on several canon clc 3200, so i would have a close look on it
              • tcs04
                FORMER Techie
                • 1183
                Originally posted by stavrator
                Hello everyone,
                See attached
                Clean the MUSIC sensors, these can get dirty! They will case a line position adjustment (MUSIC) error.
                Any SC codes? (Print SP5990 04)
                Could (?) be the belt speed sensors
                pspahr...
                Learn "Mirror Unit for Skew and Interval Correction"... Impress the trainer!!!!
                (Motors move the barrel toroidal lenses to adjust the image position for the COLOURS.... NOT black)
                • Jonza
                  Hi all,
                  For me that looks like a color registration error. Did you try Sp2111 (Forced Toner position)?
                  I use that Sp where colors are not on the top of each other
                  • moonwalker3778
                    • Jun 2008
                    • 87
                    hi friends a basically iam a konica minolta tech,ur prob common in KM color machines.u clean the MUSIC sensors said by tcs04(member).in our case we callas transfer belt image registration sensors.
                    • teebee1234
                      • Jul 2008
                      • 1670
                      Belt speed sensors are under the rear edge of belt. There is a metal plate about 1x2 in. that pinches the belt to surface of the sensors. Remove the plate and lift up the belt to access them. Use alcohol on them (also the MUSIC sensors) to help alleviate toner sticking to the lenses.
                      • SteveF
                        Field Service Manager
                        • Jul 2012
                        • 49
                        Re: ricoh mp c6000
                        defo looks like colour line calibration or music sensors ...
