savin2545/ricoh1045
  • digicor
    • Jul 2008
    • 1153
    savin2545/ricoh1045
    I have a savin2545 with light copies .... I have R/R
    DV,DRUM,Charge Roller,Tranny belt / bld and everyything related, I have ran laser test, good,It act like the dv is old or bad, its new type 18.is type 18 ricoh , the prob?Im not familiar with any savin DV. I am out of ideas.
    any suggestions would be helpfull. the mach has 600k on it
  • Jomama46
    • 2900
    It s the right developer. For light copies the first thing to do is clean the laser slit glass. Clean the ID sensor, and run the init at SP3001.
    Were the copies good right after the dv change or later?
    sigpic
    A+; Network +; PDI+
    • digicor
      • Jul 2008
      • 1153
      the copies were never good from the start,
      and i cleaned the slit glass.
      ok the dv is the right one, thats good. thanks
      • Jomama46
        • 2900
        Check SP2201 (Dev bias) someone may have raised the settings for dirty copies. Set to default
        sigpic
        A+; Network +; PDI+
        • aabarnes1
          • Mar 2009
          • 620
          Customer could have let the toner run really low, try a forced toner supply once in sp2xxx, see if it makes any difference. if not then clean your mag roller and replace your dev. Also check the drum unit is seated correctly, ie the catch/retainer is engaged
          Grant me the serenity to accept the things I cannot change.
          • Fearless V K
            • 620
            Poor transfer maybe? Check the spring contacts and contacts underneath the transfer unit.
            Don't take that toner with me!
            • nmfaxman
              • 1702
              Following the thought of "Fearless V K" check to make sure clutch is moving the transfer belt onto the drum, and that the transfer belt is even turning.
              Just something else to check.
              • digicor
                • Jul 2008
                • 1153
                thanks guys for all the suggestins
                ill post anything that worked
                • Scott_Lewis
                  • Mar 2007
                  • 519
                  Got it fixed?
                  Could also print out the non-default settings (sp5990-6) to see of anything is out of whack settings-wise. I have to do this as we have a few 'tweekers' in our shop.
