Hi Guys, When i print the colour print test pattern from printer sp mode, the cyan and magenta are askew compared to the black, i have reset mirror motor (sp) and re run line position adjust, it seems like laser related as its skewed on colours only, any ideas?
Colour skew on 2238
I recall an adjustment procedure for the 3228/35/45. It calls for printing a certain pattern, using a loupe and following a set procedure. Are you using that?sigpic
A+; Network +; PDI+Comment
I have had skew before and have solved it by pulsing the mirror motors 127 pulses either way then running forced line adjust, i think the motors must stick sometimes.Networking skills are advantageous but use of a 3m vacuum cleaner is essentialComment
You may want to try a different Transfer Unit to rule it out. We had 1 case recently where one of the Roller Shafts on the Transfer Unit was stalling and caused color misregistration. The Color Registration setup passed setup correctly, so you could only see the color misreg on the copies.Comment
