Help!! getting a SC 201 error on new ricoh cl7200
  • cmarrero76
    • Aug 2025
    I setup this printer a few weeks ago. New from CDW. Printed about 650 pages and gettinga SC 201 error when printing. anyone know how to reset? I've read how to get into service more, but not sure where to look or if it's something i need to replace. thanks
  • JustManuals
    • Jan 2006
    • 9838
    Polygon motor mirror error.
    Paul@justmanuals.com
    • cmarrero76
      any clues how to fix motor or reset error?
      • JustManuals
        • Jan 2006
        • 9838
        Replace it.
        • cmarrero76
          where can i order or find what the part # is?
          • cmarrero76
            also, do you have a repair manual for a CL7200 on your site?
            • JustManuals
              • Jan 2006
              • 9838
              Yup!
              Copier-Printers-Fax - products new home -
              • tcs04
                FORMER Techie
                • 1183
                SC201 is the polygon mirror motor (see attached)
                Reset is Switch off / on main switch.
                You shuold be able to replace the motor under warranty.
                • damionfrancis2003
                  SC202 for the aficio SPC811DN (HELP!!)
                  i just got it and as soon as it was turned on it gave the functional error turn off and on if it still persists.... u know the rest
                  SC202 - what code is this
                  help me please anyone
                  • Scott_Lewis
                    • Mar 2007
                    • 519
                    Haven't done much with this model. But here is the T/S info
                    202 D
                    Polygon motor error 1: ON timeout
                    The polygon mirror motor does not reach the targeted operating speed
                    within the specified time after turning on or changing speed
                    􀂃 Defective or disconnected harness to polygon motor driver board
                    􀂃 Defective polygon motor driver board
                    􀂃 Defective polygon motor.
                    1. Replace the polygon motor.
                    2. Replace the laser optics housing unit.
                    3. Replace the harness.
                    4. Replace the EGB.
                    • PinevskiS
                      • Jul 2009
                      • 283
                      polygon mirror
                      there are have 2 polygon mirror's
                      • PinevskiS
                        • Jul 2009
                        • 283
                        polygon mirror
                        there are have 2 polygon mirror morpr's
                        • PinevskiS
                          • Jul 2009
                          • 283
                          [QUOTE=PinevskiS;93591]there are have 2 polygon mirror motors
