DSc424 Frozen display
  • Jomama46
    • 2900
    This machine will make a copy and can even change the quantity but nothing on the LCD works, no responce. Wont respond to 1993 calibrate either.
    We have replaced the LCD and LCDC with the new types, replaced the SIB and BICU with no change. Any ideas out there?
    sigpic
    A+; Network +; PDI+
  • Vulkor
    • Jun 2009
    • 946
    Oh God, I'm sorry for you.. This POS machine.
    When you say LCD, you also mean the thin membrane that is the Touch part? We pulled one apart one time and the two metal contacts that surround that part were corrode with rust due to some liquid being spilled in there long ago. The Screen was fine as was the touch panel. Was those two metal pieces.
    Got an entire console to swap for testing?
    • Jomama46
      • 2900
      Good thought, I'll check it out tomorrow,yep replaced the touch panel too.
      No got no complete panel.
      sigpic
      A+; Network +; PDI+
      • bat
        • Sep 2008
        • 140
        Ive seen a case on A6513, that a mice eat and cut a one wire of control panel harnes, all funcions were ok, exept tuch screen....good luck
        • ricohrice
          • Dec 2008
          • 41
          Service Bulletin #38 Dated 6-2-09 is supposed fix this problem. Did you install the new style touch panel?
          • Jomama46
            • 2900
            Yes, new style installed. I am going out this am, to check all the connections, the only board left is the controller and I cannot see a connection to that.
            Something is missing.
            sigpic
            A+; Network +; PDI+
            • Vulkor
              • Jun 2009
              • 946
              Best of luck let me know how it goes.
              • Jomama46
                • 2900
                When the tech put the touch panel in, he installed it backwards so that the ribbon cable wasnt making a connection. 10 minute fix.
                When I asked him about it, he said "I put it in just like I took it out"
                um humm.
                When will I learn to question the little things?
                Its hard to soar like an eagle, when you're surrounded by turkeys.
                sigpic
                A+; Network +; PDI+
                • Vulkor
                  • Jun 2009
                  • 946
                  Sounds like issues with us sometimes lol.
                  • tcs04
                    FORMER Techie
                    • 1183
                    um humm.
                    Tech Rules
                    1) NEVER Volunteer!
                    2) NEVER assume!
                    3) What did the Customer do?
                    4) What did the Tech do?
                    3) Was it working when he arrived? was it working when he left?
