DSC 424 Faxing On Internal Phone system
  • james.makepeace
    • May 2025
    Hi
    We have got a DSC 424 on our internal phone system which means that we have to put "9" before the number that we want to dial
    and if somone forgets to put 9 it rings the switch board
    is there anyway of getting the copier to put 9 for the user so they dont have to remember to put the 9?
    James
  • Eric1968
    • 2458
    IN SP3-103-002 (Fax SP) you can input the PSTN Access number. I don't know if that means that you don't have to dial 9 to get an external line, but maybe it's worth a try.
    • Jomama46
      • 2900
      exactly what it means.
      sigpic
      A+; Network +; PDI+
      • james.makepeace
        What does it mean i guess it means it would work so the 9 wouldnt have to be entered ?
        If so how would i do it on the copier ?
        dont know what SP3-103-002 (Fax SP) is ?
        • Jomama46
          • 2900
          It means the 9 is automatically dialed first when a ph number is entered. SP is a special service mode and you should call a tech if you dont know what it is. They will know how to input this info.
          sigpic
          A+; Network +; PDI+
          • james.makepeace
            Hi would you be able to tell me how to do it i have phoned the tech support that we have got on the copiers and i have been told it cant be done
            James
            • Jomama46
              • 2900
              Just give them this info from Eric "IN SP3-103-002 (Fax SP) you can input the PSTN Access number"
              If I tell you how to get into service mode and you push the wrong button, you can cause more problems and since you wont know what you did wrong, you will spend even more money trying to find out.
              sigpic
              A+; Network +; PDI+
              • james.makepeace
                I know how to get in to it
                Yellow
                107
                Clear/stop
                and then got to sp3xxx
                103
                002
                But what do i need to put in ? it come up with letters?
                James
                • james.makepeace
                  Yellow
                  107
                  Clear/stop
                  103
                  002
                  James
                  I got in and put a 9 in the box and pressed # and it asked me to rewrite so i did that and it still only dials internaly and doesnt use the 9?
                  pls help
                  James
                  • Jomama46
                    • 2900
                    Set 3-103-001 to PABX
                    sigpic
                    A+; Network +; PDI+
                    • james.makepeace
                      Hi
                      i tryed that and it still doesnt seem to want to work any more idea's?
                      James
                      • Jomama46
                        • 2900
                        No but keep us updated on your progress.
                        sigpic
                        A+; Network +; PDI+
                        • james.makepeace
                          Hi Is what i am doing right going in to the SP3-103-001
                          Setting it to PABX (have tryed it in PSTN)
                          and then going into 002
                          pressing the 9 key and then # and then pressing yes when it asks when i want it writing to memory ?
                          I have also noticed there are some other lines in there how do i know which one i am using or does it default to the one i been working on
                          James
                          • Jomama46
                            • 2900
                            Sounds right, but without a 424 w/ fax option in front of me, I can't really tell for sure.
                            sigpic
                            A+; Network +; PDI+
