scanrouter question, auto-resume services?
  • stasis
    • Aug 2025
    hi all, first post here. i have a question regarding the scanrouter v2 software. every night at 11pm when a backup is performed, the scanrouter services are suspended - since it doesnt look like the "resume services" option in the admin console refers to the actual scanrouter service (in windows services), i havent been able to figure out a way to turn this back on automatically without having to touch the box every morning. is there any way to automatically resume delivery services at a specific time?
    thanks
    joe
  • imaginemoko
    unTrusted Tech
    • Jan 2008
    • 289
    i think in scanrouter there is no time to be set to resume the service.... its a problem if you have a 24 hours office and need to use scanning after 11pm but if none a few clicks in every morning to up the service is not a hard work i guess....
    fix the customer first then fix the machine... its simple and makes life more easy.
    • stasis
      true it isnt hard, it just annoys me that I cant script it in some way. any ideas anyone?
      • KopyKat
        Nurse Ratched of Repair
        • Nov 2008
        • 365
        You could try using Task Manager to set up a time to run Resume Services there should be an executable in the ScanRouter Folder. Or hop over to the Connectivity Forum and see if there someone there willing to write you a script.
        Depending upon the backup software you are using...many will stop certain programs and then run them upon completion of the backup.
        Good Luck!
        sigpic
        Relax! This firmware injection won't hurt...but it will take 45 minutes.
        • stasis
          i was looking in the folder trying to figure out what it might be, there are a lot of different executables in there, so far nothing concrete. i'll keep trying
          • KopyKat
            • Nov 2008
            • 365
            Look for this: DdsLaunch.exe That is the program that starts the delivery Services.
            sigpic
            • stasis
              thank you very much, I think I'll be able to put something together using that.
