Savin 8025e showing D006 Product Code
  • nmfaxman
    • 1702
    Tried to upgrade firmware on Savin 8025e. Firmware on machine is D006***.
    Upgrade firmware is D007**** and machine won't recognize it.
    I need to upgrade the firmware to install the HDD address book and set up LDAP.
    I am thinking of renaming the file on SD card to D006***, but don't know if it will work and I don't want to screw up the machine if I can get away with it.
    Ricoh tech site doesn't even show D006 anywhere, even when I search.
    Has anyone else run into this?
  • tcs04
    FORMER Techie
    • 1183
    D006.... is for the Ricoh MP3010 series
    • Jomama46
      • 2900
      D006 5931H is the latest version of the firmware. All of the past versions have been D006 also. I dont see any listed as D007.
      sigpic
      A+; Network +; PDI+
      • Vulkor
        • Jun 2009
        • 946
        Well the 8025e is the D007
        I checked the Firmware on the TSC. All them say they are for the D007.
        But if you look at firmware history you have
        Fax Firmware is
        ver1.00.00
        D0065932A
        July 2006 production
        IF you are worried what the files are named then don't. I'm pretty sure it doesn't matter long as they are on the SC card properly.
        One Firmware file at a time.
        The SD card should have nothing on it but Romdata\D007 and your firmware.
        • Vulkor
          • Jun 2009
          • 946
          Then how do I get
          Ricoh D008
          MP 3010 MP 3010SP MP 3010SPF MP 3010SPi MP 3010P
          • tcs04
            FORMER Techie
            • 1183
            Originally posted by Vulkor
            Then how do I get
            Ricoh D008
            Not sure, I work on Ricoh kit in the UK and the D006 firmware relates to the MP3010 series, I'm not sure of the related Savin models.
            • nmfaxman
              • 1702
              Firmware for the D006 fax is still v.1000.
              I need to update the controller to see the HDD... to accept LDAP.......to make it work on a terminal services LDAP network.
              Once again IT never told me it was in this format and expect me to jump through hoops.
              If I new the situation beforehand I would have known what firmware it needed and upgraded it at the same time, and this post would have been here 2 weeks ago.
              Scan to email works, and printing from my laptop works fine.
              Ranting but I need an answer.
              Thanks.
              • Scott_Lewis
                • Mar 2007
                • 519
                I've updated every MP2510 I service. My SD cards looks like....
                ROMDATA
                D007
                D310
                Those two folders were based on whatever was embedded in the zipped file. Funny thing is there isn't a one D007 or D008 file in the bunch. Most of my files are D310s and ....... what the heck here is a directory listing
                Volume in drive D is Data
                Volume Serial Number is E0F7-6CD1
                Directory of D:\WorkStuff\Ricoh\MP2510_3010\Firmware\LatestVers ion\Romdata
                07/24/2009 10:44 PM <DIR> .
                07/24/2009 10:44 PM <DIR> ..
                10/02/2008 10:39 AM <DIR> D007
                10/02/2008 10:38 AM <DIR> D310
                07/24/2009 10:44 PM 0 files.txt
                1 File(s) 0 bytes
                Directory of D:\WorkStuff\Ricoh\MP2510_3010\Firmware\LatestVers ion\Romdata\D007
                10/02/2008 10:39 AM <DIR> .
                10/02/2008 10:39 AM <DIR> ..
                10/02/2008 10:31 AM 8,824,972 B2095530B.fwu
                10/02/2008 10:31 AM 4,194,800 B2095541C.fwu
                10/02/2008 10:34 AM 2,097,644 B2095550H.fwu
                10/02/2008 10:32 AM 3,080,712 B7665570D.fwu
                10/02/2008 10:35 AM 816,476 B7675387C.fwu
                10/02/2008 10:28 AM 10,192,744 D0065931H.fwu
                10/02/2008 10:29 AM 1,008,800 D0065932A.fwu
                10/02/2008 10:33 AM 746,116 D3105125D.fwu
                10/02/2008 10:34 AM 736,748 D3105385A.fwu
                10/02/2008 10:30 AM 30,068 D3105941A.fwu
                10/02/2008 10:33 AM 1,064,772 D3105942A.fwu
                10/02/2008 10:34 AM 1,801,492 D3185105A.fwu
                12 File(s) 34,595,344 bytes
                Directory of D:\WorkStuff\Ricoh\MP2510_3010\Firmware\LatestVers ion\Romdata\D310
                10/02/2008 10:38 AM <DIR> .
                10/02/2008 10:38 AM <DIR> ..
                10/02/2008 10:33 AM 1,668,444 D3105381E.fwu
                10/02/2008 10:34 AM 831,360 D3105382B.fwu
                10/02/2008 10:32 AM 2,325,816 D3105384E.fwu
                10/02/2008 10:35 AM 2,350,660 D3105386B.fwu
                10/02/2008 10:32 AM 1,929,964 D3105388D.fwu
                10/02/2008 10:29 AM 426,624 D3105389A.fwu
                6 File(s) 9,532,868 bytes
                Total Files Listed:
                19 File(s) 44,128,212 bytes
                8 Dir(s) 490,207,580,160 bytes free
                I wouldn't hesitate to apply these to any MP3010's I come across. This is what I carry along with a set for the MP3500 in my kit.
                ps I haven't checked for recent updates as I have a non-standard version of controller software on all the machines in my territory (AFB). I'm a bit leery of compatibility issues between the older controller firmware and newer versions of other firmware.
                • nmfaxman
                  • 1702
                  Here is the printout of the firmware.
                  I know I put it on the SD card right because I updated a 2238c the day before.
                  I don't know if I should do the B209, D007 or try to find the D006.
                  I need to upgrade the system software so it will see the HDD.
                  • tcs04
                    FORMER Techie
                    • 1183
                    As long as you put all matching firmware in the romdata folder on the SD card, the machine will only accept the correct frimware, so if you mix within the folder the machine may not see any!
                    • Scott_Lewis
                      • Mar 2007
                      • 519
                      Did you get this squared away?
