Ricoh Aficio 1045
  • tcypy1961
    • 773
    Ricoh Aficio 1045
    I'm having a problem with misfeedingfrom tray #2. I'm thinking the torque limiter might be the problem. The copier will feed about 5-10 copies from tray #2 ok then the fun starts. First it would fold the lead edge corner closest to the front side of copier mainly when running the paper 8.5x11R. I let a misfeed stay where it stopped and removed the vertical transport cover (right side) and the only thing I thought might be causing the problem was the lower support plate that attaches to the cover. It appeared to be bent in causing the paper to catch on the cover. Reforming the plate did not help. When running the paper through 11x8.5 at times the paper will not run smooth off the tray it buckles then folds just as it leaves the tray. I have replaced all pf pulleys and cleaned all the pf clutches. Paper feeds fine out of trays 1,3,and 4. I also suspected their paper but problem happens with new paper as well.
    Thanks!!!
  • Fearless V K
    • 620
    I have only seen this happen when the clutch sticks... sometimes you can't clean worn out.
    Don't take that toner with me!
    • TonerMunkeh
      Professional Moron
      • 3865
      Look at the corner seperators on the tray too. Are they slightly bent or missing? Are the side fences tracking correctly? Both items have thrown me for a curveball before.
      Hit it.
      • Scott_Lewis
        • Mar 2007
        • 519
        Check to make sure the lift tray is level across the right edge of the tray. Do you have a broken tray hinge? Basically, is the paper level when in the lifted position and presented to the feed rollers.
        • gernah
          • Jun 2009
          • 57
          Thanks!!!
          Sir,good day!did you replace already the electrical clutch and transfer unit clutch please replace it your problem its solve.goog luck and make happy!
          • tcs04
            FORMER Techie
            • 1183
            Thanks!!!
            Swap the tray with station 1! if the fault moves, it's the tray. If not, do the same with the PF rollers / torque limiter. Are the the vertical transport guides in good condition?
            This should narrow down the causes.
            • b003ace
              • Jun 2008
              • 78
              Replace the feed, relay, and registration clutches. Cleaning won't restore the magnetic field to full strength, and the clutches are cheap enough. Hell, when I worked on these I carried a complete set of feed, relay, and regi clutches in my car. I don't think I ever replaced a torque limiter on one of these feeds.
              • tcypy1961
                • 773
                I would agree with the clutches if it would explain why three clutches are needed for only one casette having the misfeed problem. There are 4 trays plus the by-pass. Only tray 2 has the problem???
                Thanks!!!
                • b003ace
                  • Jun 2008
                  • 78
                  Thanks!!!
                  Because,
                  1) The timing between the clutches can vary as their effective strength weakens with age, and
                  2) You're already in there, one is almost certainly bad, and that means at least one other will fail soon. Why waste time going back repeatedly, first fixing tray 2, then tray 1, etc.
                  3) You're avoiding the dreaded CALL BACK.
                  If you have a paper deck as well, I'd probably put all the clutches in it as well.
                  These clutches only need to slip a little to mess up the timing to registration, the amount of buckle, and I've even seen them cause a z-fold. Compared to the cost of multiple trips and call backs, the clutches are cheap. (That's why they fail, too, they're cheap)
                  Another thing that some techs miss is the hinged paper guide that snaps into the feed. They get knocked out of place, but it isn't obvious.
                  Last, I have seen the actual paper feed frame (plastic housing) broken where the tabs hold it into the steel frame of the copier. Still, whenever I've had feed issues on A232, A283, B003, or B079 series machines, clutches fixed it nineteen times out of twenty. And, the part numbers for most of these clutches have been changed, the clutches were re-designed. That should tell you something as well.
                  Now, if you were talking a 1027 series product, I'd tell you to look at the jaw on the lift mechanism in the rear of the frame. The nylon jaws on those models split, making the lift pressure fluctuate. But the 1035 doesn't have those bad nylon jaws. If the clutches don't solve it, I'd definitely look at lift pressure.
                  • tcypy1961
                    • 773
                    I do agree with you all in that pf clutches can and do attribute to pf troubles yet I would hope after 25 years in the business I would recognize a clutch problem. This does not look like a clutch problem to me. I'm not seeing the types of folds in the paper that a feed clutch would cause. What I see happening to the paper is happening right as the lead-in pulley starts to feed the paper in. If the copier used 2 lead-in pulleys spaced out like some copiers do I'd be looking for a worn pulley due to insufficient pressure on one side. It's like the paper is twisting as it starts to feed in. I've pulled all the covers on the right side of copier off and adjusted a plate that I felt was the cause and might still be; however the twist when it's bad happens in the tray just as paper starts to be pulled in. So I feel it's either their paper or the torque limiter is doing something funky. I will however be bringing clutches with me just for funssies.
                    Thanks!!!
                    • Scott_Lewis
                      • Mar 2007
                      • 519
                      You say the paper looks to be twisting (skewing?) as it is being pulled from the tray. That still sounds like a problem of the paper not being flat (broken hinge of the lift tray) against the roller. If the paper tray is level, then perhaps the roller is not level.
                      Check to see if the roller shaft or roller/feed assembly isn't bent. You could always try putting a thin coating of toner on the roller to see it's 'footprint' on the paper.
                      • Matoku
                        • 173
                        For me all the way I have seen it the pf clutch that aging. sometime service it can solved the problem but not always lucky enough.I've to change the clutchs. it happen because of the pf clutch delay to release.
                        • PA5RR
                          • Aug 2009
                          • 62
                          Hi folks!
                          Most feed problems with tray 2 are caused by a user removing paper the wrong way.
                          Check the black papertransportguide if its in its original position.
                          You may have to remove the right covers to access it.
                          Good luck and tell all of us wich solution was the correct one ?!
                          technicians are the only ones that don't trust technical stuff !
                          • Brave Hart
                            • Aug 2009
                            • 73
                            I agree with the clutch replacement! Once they start doing that you replace them. Cleaning them only helps for awhile before the start playing up again.
                            What? HuH?
