ricoh 2232c sc 471
  • ash_572
    • Oct 2008
    • 523
    ricoh 2232c sc 471
    machine jammed first thing in the morning on the right hand side of the machine. its also made this grinding noise from the transfer unit like its struggling to turn.
    this is happening first thing in the morning. its happend twice already.
    there is an modification on this sc code about a plastic mylar could this be the problem thts causing this?
  • CableGuy
    Impulse Drive Engineer
    • Oct 2008
    • 417
    Yep, that little mylar at the entrance of the transfer unit is prob'ly bent and needs replacing. It could be causing the unit so get stuck when it tries to move up or down. Replace it and give the little sensor a clean that is attached to the back wall of the machine while you've got the transfer unit out. That's the one that throws up the SC 471.
    I have had problems in the past with the mylars and the sensors, but replacing the mylar ususally gets you out of trouble.
    Good luck
    • ash_572
      • Oct 2008
      • 523
      spoke to someone at ricoh earlier on. they said to replace the clutch in the transfer unit.
      thanks for the response.
