Aficio 1075 Scanner Setup
  • Matoku
    • 173
    #16
    try also use the twain scanner driver and the desktop binder lite ( free download ) for your desktop interface. its easy to use the scanner function.
    first install the twain scanner driver then install the desktop binder lite.after desktop binder lite installed you have to restart you pc.after restart you will see the palette tools at right bottom side, go to extanded features and in scanner click the properties and select the scanner you want to use as default scanner.
    this only for push scanner function or what we call twain scanner.
    • aaalexxx
      Engineer
      • Jul 2009
      • 51
      #17
      scan to email?
      simple and easy. =)
      • vanigold
        #18
        Scan the folder must be shared and full otherwise controlled not work.
        • Venom
          Technical/IT Support
          • Nov 2009
          • 765
          #19
          Scan to email is easy...FYI: older firmware doesn't allow smtp authentication so you would need to update firmware
          IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
          • un4rgiven
            • Dec 2014
            • 8
            #20
            Re: Aficio 1075 Scanner Setup
            hi there
            is it possible .aficio 1075 does't have scanner ??? i pushh scanner button just have a bipp and nothing work... i ask service they say some version dont have scanner :-O
            • sandmanmac
              • 3981
              #21
              Originally posted by un4rgiven
              hi there
              Yes. But the fact that it has the button, means that it once had a scanner that has since been removed
              • un4rgiven
                • Dec 2014
                • 8
                #22
                thank you for answer... how can i know it removed or already there isnt scanner.
                • mikadonovan
                  • May 2008
                  • 2931
                  #23
                  The print/scan option consists of these things.
                  NEVER ASSUME ANYTHING
                    • 37533
                    #24
                    Check the setting of SP 5985-001. If it is set to 0 all scan funstions, including the scan button, are disabled. Network printing is also disabled. Change the setting to 1.
                    • tonerhead
                      • Sep 2009
                      • 582
                      #25
                      Hit counter/user tools. If it has a scanner installed, it will show up there. Another work around is to use the network twain scanner driver with Irfanview. Although Irfanview is technically for private use only.
                      I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
                      Especially when it comes to sex
                        • 37533
                        #26
                        I am not sure for the 1075, but with the newer equipment if the NIB is disabled in SP 5985-001, the scan option is disabled and will not show in User Tools. You cannot even assign it to the Home Screen. I know from recently installing Print/Scan option on a MP 5002.
                        • un4rgiven
                          • Dec 2014
                          • 8
                          #27
                          hi i must say this solution. i open the kit or board guard and see there is just printer kit.look like laptop rams.. one of other friend have 1075 and when i watch for him i see there is one ram and write scanner and printer kit... i find that kit and now my scanner option is work!!!! now i try to setup scan to computer ... before i change the rams my password at pc (when use device's ip)
                          is ADMIN-ADMIN . BUT NOW ITS DONT WOTK .
                          • un4rgiven
                            • Dec 2014
                            • 8
                            #28
                            • un4rgiven
                              • Dec 2014
                              • 8
                              #29
                              any one know easy way to scan to folder from 1075??
                              i find smart device monitor for admin but don know how to work... but how can i use web image monitor and send scan for shared folder??
                              • mikadonovan
                                • May 2008
                                • 2931
                                #30
                                I think your pretty much stuck with scan to email (imbedded). Scan to folder on this model used Scanrouter, which hasn't been supported for years, and was major glitchy anyways.
