Aficio 1075 Scanner Setup
    • 37532
    #31
    Re: Aficio 1075 Scanner Setup
    One other option is to use TWAIN scanning and software that can take advantage of it.
    • un4rgiven
      • Dec 2014
      • 8
      #32
      ONE OF my friend have 2060 and when u go on device ip there is document server tab but i dont have document server at my device (
      i try smart device monitor for admin but .....
        • 37532
        #33
        If the HDD has been removed, the document server will not be available as there is no place to store it.
        • un4rgiven
          • Dec 2014
          • 8
          #34
          rly !!! how can i fix it?? but when i watch the board there is a internal hard drive u can see at pic i insert at post...
          • un4rgiven
            • Dec 2014
            • 8
            #35
            see here say document server Capacity but....
            • AjitN
              • Mar 2009
              • 287
              #36
              Hi all
              I managed Scan to Folder using ScanRouter V2 Lite & Windows 7 on Aficio 2035.
              Every thing is working OK although few options are not available.
              Problem is I am not able to get scanned file in PDF format even all the settings on SR & MFP is set to Multi-page PDF. It is delivering as JPG or TIFF. Hence file size is very big and it is troublesome to convert that again in PDF format.
              Please suggest if there is any workaround or some setting on SR or MFP.
              Thanks in advance
                • 37532
                #37
                Originally posted by AjitN
                Hi all
                Thanks in advance
                User Tools - Scanner Features - Scanner Settings - Next -File Type Priority
                • AjitN
                  • Mar 2009
                  • 287
                  #38
                  As I mentioned in post I have set Multi-page PDF in ScanRouter's Preferences optioned and also on MFP (in User mode - Scanner Setting - File type Priority ) as PDF.
                  Still I am getting file in shared folder on comp as TIFF.
                  If I set Grayscale on SR Lite and scanned document using grayscale option from MFP, I am getting JPG formatted file in Shared folder but not PDF.
                  Thank you for support
                  • TonerMunkeh
                    Professional Moron
                    • 3865
                    #39
                    Honestly, you need to upgrade this dinosaur and get a machine that can scan to folder itself without the need for Scanrouter.
                    Hit it.
                    • Iowatech
                      Not a service manager
                      • 3930
                      #40
                      Also, the 2035 is quite different than the 1075, so you would find more joy starting a new thread rather than looking for answers here.
                      You would help others by starting a new thread too.
                      • AjitN
                        • Mar 2009
                        • 287
                        #41
                        I am not very keen to resolve this problem but just wondering if all the settings for 2035 & 1075 are same then in case of 2035 why PDF is not being generated. Just wanted to get some more information & learn something new,
                        Thank you all again
