have sc 955 what is it and how do i fix it my disc is dead.sorry guys wrong code SC955.SOFTWARE ERROR SO I REPLACED BICU NO CHANGE
ricoh 1035/45
Recipients: hodgiepodgie
5 Days Ago iMind
Vacuum Cleaning Expert
your link
Hi Paul here is your link:
http://ul.to/zxdji1
Cheers
PaulsigpicWe can all Win, but at the end we all loose. Save the greyhound -
Did you by any chance replace or work around the controller or IOB boards prior to this happening?Comment
SC995: Machine Type information error (A)
After the machine is powered on, a mismatch is detected between the CPM information sent from the controller to the engine and the CPM information specified by the IOB DIP SW settings.
The 35 and 45 CPM machines use different boards and the DIP SWs must be set correctly.sigpic
A+; Network +; PDI+Comment
HMMM
easier said than done most customers will not spend the money.anyway replaced hdd will see so far so goodComment
It would be cheaper to give them a machine free and charge them them on the clix, Honestly my friend I would not put a part into a 1035/45 cos in 6 months you will not be able to get the parts to make this machine a viable comodity. Try your best to point the customer forewardGrant me the serenity to accept the things I cannot change.Comment
Sadly many people refuse to change machines till theirs DIE. I wish we could pick them up and say oopps non repairable its dead. But the BOSS refuses to do that.
We have old 9918dp, 9922, 2534/34, and even old Analogs out there we still support such as 9013z (1994 DAMN) and 9935. We keep telling customers look one day it'll be we can't get the part and you are done for. They are ok with it.
Just had a church trade in a 9935 with only 235k copies. Go figComment
