Savin c 3828 (rich0 a 2238c\lanier ld 238c) jam code
  • copierlady
    • 338
    Working on savin c3828 giving a j001 code and instructs user to open rt side door and remove jam. No jam in machine. Sounds like a paper sensor. But, the only sensor i find for this machine is "id sensor in paper exit unit" ( p/n b1805450) the exit is on the left side of the machine. Any thoughts? Thanks
  • Shadow1
    • Sep 2008
    • 1642
    J001 on most Ricoh machines translates to "Paper in machine at startup" but doesn't tell you what sensor the paper was at. If the machine was turned off/on to try to clear a jam check your jam history SP7507-002 to find out what the original jam was (7507-001 will be the 001 code) If the machine is only reporting J001 start with the door switches - when they get dirty they get flaky and any vibration is enough open them just long enough to stop the machine. Since there was no actual jam the machine logs the J001 because the door was closed with paper still inside. Don't forget the finisher door switches too, as these seem to be the highest failure on most machines. (except the LD245)
    73 DE W5SSJ
    • Jomama46
      • 2900
      Also if paper never leaves the tray, it will indicate a jam.
      sigpic
      A+; Network +; PDI+
      • Shadow1
        • Sep 2008
        • 1642
        Yes, but it won't be a J001 - it would be a J003 or a J051 depending on if it is a leading or trailing edge jam (doesn't hit the sensor in time or doesn't leave the sensor in time) That's assuming it is tray 1 jamming, for tray 2 it would be J004 / J052 and so on...
        BTW, for any Ricoh Newbie's who stumble on this thread, the jam codes can be hard to find in the SM - they are broken down in SP7504, so the easiest thing to do (if you can get the machine to print at all - if not you can still look at it directly) is to print the SMC logging data - SP5990-004. You then have the jam table, number of jams in each location, 10 most recent jam locations including meter counts, and recent SC codes. It's really useful not only for fixing the current problem, but it can help spot something that's going to be a problem soon.
        Last edited by Shadow1; 09-01-2009, 09:47 PM. Reason: typo - probably not the only one
        73 DE W5SSJ
        • copierlady
          • 338
          THANKS
          Thanks guys not going back out there until tue. I'll let ya know. I love the little man hitting his head against the wall, thought it was my shadow for a sec there!
          • bbapst
            • Dec 2008
            • 42
            i agree with the finisher door switches or the switches between the finisher and the copier, check the bracket that holds the two switches. it can get bent if the customer slams the finisher against the copier. quick way to check is to shake the finisher and see if the door open light comes on.
            • copierlady
              • 338
              STILL STUCK
              I AM STILL WORKING ON THIS BEAST. ANYONE HAVE ANY FRESH IDEAS?
              THERE IS NO FINISHER ON THIS MACHINE. I CHECKED THE DOOR SENSORS UNLESS I AM MISSING ONE SOMEWHERE. I TRIED DISCONNECTING THE LCT IN DESPERATION. NO CHANGE. I HAVE ALSO REPLACED THE EXIT SENSORS. THE JAM CODE SHOWS THE LETTER "A" BUT THE DOTTED LINE ON THE PICTURE SHOWS THE WHOLE PAPER PATH. CAN I TRUST THAT IS IS AT LETTER "A" OR NOT? IF YOU CAN'T TELL I AM REALLY OVER THIS AND SO IS MY CUSTOMER! IT IS SO FRUSTRATING BECAUSE IT SHOULD BE A SIMPLE FIX. THANKS FOR ANY ADVISE.
              • Koosie
                • Nov 2008
                • 121
                I think maybe there's a sensor that's not working or actuator broken somewhere in the machine. Go to input check in the SP modes. Page 5-114 in the manual. SP 5-803-5 to 6 should all be zero's. If there's a 1 then you can check in the manual witch sensor is detecting paper in the machine. Remember, a faulty sensor cable or plug that is not plugged into the board can also cause this.Thats the only thing I can think of that is causing this.
                Good luck!
                • copierlady
                  • 338
                  thanks
                  thanks i will give it a try in the morning and let you know.
                  • paperclipsandbubblegum
                    • Sep 2009
                    • 29
                    Are you able to feed at all ? What about other trays ? Assuming the feeds and torque limiter are OK, I would consider changing out yhe feed clutch.
                    • copierlady
                      • 338
                      NO FEEDING
                      The code will not clear at all. I can not feed from anywhere. The customer has a note taped to the lct telling people not to use it because it does not work, so we have tray one and bypass to work with for now. But, not until i get this pesty code to clear! I AM A KONICA TECH WORKING FROM ONLY WHAT I CAN GET FROM INTRAVIA SO I MAYBE MISSING SOMETHING IN THE SP MODE. SOMETIMES YOU HAVE TO READ BETWEEN THE LINES TO UNDERSTAND WHAT HE IS SAYING. THIS COULD BE A LOT OF MY PROBLEM WHEN WORKING WITH INPUTS. BUT I'M NOT GIVING UP YET!
                      • Koosie
                        • Nov 2008
                        • 121
                        So the machine feeds from tray 1 and bypass, but not from LCT? If that is the case, the code must have cleared and the machine is jamming from LCT.
                        • copierlady
                          • 338
                          jam code
                          The lct has never worked, and i completely disconnected it to see if that would clear the code. No good. When you turn the machine on it come ready for about 2 sec. Then it diplays the j001 code and shows the letter "a" on the screen wtih a dotted line indicating the paper path through out the machine, and indicates to open rt side and front door to clear jam. Will not clear.
                          Does anyone have a copy of the parts and service manual for this machine? (savin c3828) i must be missing some sensors when i am testing in the sp mode.
                          • Scott_Lewis
                            • Mar 2007
                            • 519
                            Forget about those codes. They are too generic to be of much use compared to the service jam codes. I don't see where you mentioned the service jam code. Go check the data in 7-507. It is timestamped and will tell you EXACTLY which sensor the machine detected an error at.
                            [IMG]file:///C:/Users/Scott/AppData/Local/Temp/moz-screenshot-6.png[/IMG]
                            [IMG]file:///C:/Users/Scott/AppData/Local/Temp/moz-screenshot-7.png[/IMG]
                            [IMG]file:///C:/Users/Scott/AppData/Local/Temp/moz-screenshot-8.png[/IMG]
                            [IMG]file:///C:/Users/Scott/AppData/Local/Temp/moz-screenshot-9.png[/IMG]
                            Another note, as a rule the only way to clear a jam indication is to clear the sensors and open/close ALL of the doors that the machine wants cycled. Power On/Off and service mode resets will NOT clear jam codes.
                            • copierlady
                              • 338
                              THANKS
                              Ok i'm gonna give it one more shot. Thanks
