MPC2500sp: <<e-mail to fax>> is it possible?
  • nobody-here
    • Mar 2008
    • 237
    So it's a strange question but my customer need this :
    He would like to send a mail with a tiff attachment to a specific address (i.e. MPC2500@domain.com) then He supposes that the MPC2500 gets this email through pop3 connection and forwards it to a normal FAX NUMBER indicated in the email itself.
    Additional infos.
    - Machine is configured as fax machine.
    - I am not so good inside IP-FAX Technology.
    - My customer is a programmer so if the email should be manipulated in some way I think he can do himself.
    Is all of this possible? Where can I get information to help him?
    Thanks a lot
    Vincenzo.
    29 rouge unpair manque.... cous cous....
  • rthonpm
    • Aug 2007
    • 2848
    No can do without a fax module I think. Without the modem and such there's no way for the machine to forward to a fax number or such.
    • Froota
      Field service tech.
      • 129
      Hi,
      The thing that bothers me is what this got to do with the ricoh machine....
      I understand that he want to use the mfp in this process, but aren't there other easier ways to do this? for example by just sending a mail or faxing by lanfax?
      Customers are really inventive sometimes and want to get it all out of the machine, but don't forget it's 'just' a copier with some extra features.....
      gr,
      Froota
      • Vulkor
        • Jun 2009
        • 946
        Wow I think I would just stare at the customer Blankly.
        Sounds like he just needs to Lan-Fax. Sending an Email to an MFP and wanting it to fax based off whats in the subject like a Fax #
        Maybe some JAVA SDK programmers and licensers with Ricoh could make that happen.
        • copyman20
          • 207
          You should tell your customer that it can be done. It will cost him $50,000.00 a year. Just hire someone to sit at the machine, when a email to the mfp prints out the $50,000.00 man (nikename 50Gman) take the paper and sticks it in the DF and dial the fax #. Or just use the lan-fax driver.
          The customer can even send and email to 50Gman to get him coffee, the mfp prints the email, and 50Gman gets the coffee and pours it in the DF and uses scan to email to email it back to the customer. Only question, which flavor does he prefer, Tiff or PDF.
          • nobody-here
            • Mar 2008
            • 237
            Ok,ok,ok....
            I knew that this was strange or impossible, but customer is our "bread" and It worth a "post on copytechnet".
            Thanks a lot guys.
            Vincenzo
            • category_five
              • 93
              As Vulkor and Froota have said, download the Lan-fax driver from Ricoh.com. It installs just like any other printer driver. It will allow your customer to print to the fax line from any application, including his Email application - no IP fax needed. It's available from Ricoh.com.
              Once it's installed by you he can simply select File, then Print, then select the Lan-fax printer. Again, this will work from any application. He will have to type in the destination phone number into the driver. The Lan-fax driver includes an integrated address book, however you should recommend that he not use the address book.
              Also as an American to an Italian, I would like to say thank you for spaghetti, pizza and lasagna. The world would be so much the poorer without Italy.
              P.S. that one tower in Pisa, it's still broken. You guys should really fix it.
              Information is intended for certified service personnel only. Your mileage may vary, see dealer for details.
              • Vulkor
                • Jun 2009
                • 946
                Lmao Cat 5. Nice
                • Jomama46
                  • 2900
                  Also as an American to an Italian, I would like to say thank you for spaghetti, pizza and lasagna. The world would be so much the poorer without Italy. don't forget Mafia and Ponzi.
                  xxxxx
                  sigpic
                  A+; Network +; PDI+
                  • Voltage
                    • Jul 2008
                    • 282
                    probably a minolta
                    • Scott_Lewis
                      • Mar 2007
                      • 519
                      Ok,ok,ok....
                      Thanks a lot guys.
                      Vincenzo
                      You sorta had to figure you were going to get a least a little good natured ribbing.
                      This almost sounds like a case of the tail wagging the dog. How about going back to your customer and finding out just exactly what they are trying to accomplish. Then YOU (with your superior knowledge of how things work) can figure out how to make it happen. Rather than THEM (with their vague understanding of how things work) trying to design the process.
                      • nobody-here
                        • Mar 2008
                        • 237
                        According to my superiori mind , Lanfax is a possible solution, but is not automatic and also not working outside LAN, btw I will speak clear to my customer and try to let them redesign their processes.
                        Pisa Tower is like Italy is: broken and bent, so why fix it. Ponzi and Mafia? Please ask to Politicians.
                        As Italian to American I would thank for MC Donald and Burgher king, my stomach would be poorer without them (I really love Crispy Chickens).
                        • Vulkor
                          • Jun 2009
                          • 946
                          What a Great Cross Culteral Conversation we are having.
