SC 300 in aficio 1075
  • aaahmmm
    • Aug 2009
    • 103
    I had an SC 300 in aficio 1075 , I pull the corona and clean it , clean the grid and wire .but the error still appear
    Note: the grid and wire life is less than 200K
  • ccchuah
    • Mar 2009
    • 152
    HT leaking at corona end block, loose contact at rear socket or maybe the charge power pack defective.
    • Brave Hart
      • Aug 2009
      • 73
      Hi there.
      At the front and back, make sure that the corona wire is threaded correctly into
      the grooves in the end blocks. I had a SC 300 the other day were it was arcing against the grid.
      What? HuH?
      • TonerMunkeh
        Professional Moron
        • 3865
        If the machine has done quite a few copies i.e. a million plus, replace the end blocks of the corona unit, they may be arcing out. Replace the grid and wire while you're at it, they're two-thirds of the way through their life so you might as well.
        Hit it.
