jams every time coming up from all the drawers b4 reg rollers under the metal guide plate that goes up and down with the right door. if i remove the transfer unit it will feed through then trip the 402 code for transfer but it goes through. i checked the transfer unit, mylars in reg area and door all ok. i can manully spin it through the rollers. it crashes into the metal guide plate b4 it gets to the nip of the 2 reg rollers. i tried to watch it by removing the lower right inner cover by the reg knob but i can't see what it could be. thnaks t
af-1045
good luck. -
jams every time coming up from all the drawers b4 reg rollers under the metal guide plate that goes up and down with the right door. if i remove the transfer unit it will feed through then trip the 402 code for transfer but it goes through. i checked the transfer unit, mylars in reg area and door all ok. i can manully spin it through the rollers. it crashes into the metal guide plate b4 it gets to the nip of the 2 reg rollers. i tried to watch it by removing the lower right inner cover by the reg knob but i can't see what it could be. thnaks tDYNAMIC OFFICE SOLUTIONSComment
jams every time coming up from all the drawers b4 reg rollers under the metal guide plate that goes up and down with the right door. if i remove the transfer unit it will feed through then trip the 402 code for transfer but it goes through. i checked the transfer unit, mylars in reg area and door all ok. i can manully spin it through the rollers. it crashes into the metal guide plate b4 it gets to the nip of the 2 reg rollers. i tried to watch it by removing the lower right inner cover by the reg knob but i can't see what it could be. thnaks tComment
This is a known problem, the guide were the paper moves between is bend.(direct before the sheet moves thrue the registrationrollers)
You just have to force it back in place.
I have also seen the plastic cap on the metal guide was put on the wrong way causing a sheet to stuck as well.technicians are the only ones that don't trust technical stuff !Comment
