I'm having a problem troubleshooting a sc:500 error on a savin 4018d? Seems like maybe motor or drive related but was wondering if anybody has any other experience with this error...
Savin 4018d
Have you tried:
SP mode 5-804. output mode for the motor?
Is the drum unit seized?
is the fuser seized/stuck together?
My guess would be to look for something thats stopping the motor from turning rather than the motor turning under its own power for the moment.
If your not familiar with the ricoh post back - someone on here will help you.
patrickj420
I have a test drum/dv unit I'm going to try tomorrow; the fuser turns but never gets warm. I get the error on power up. I can turn all the units manually. If I power up the machine with the drum out it prompts me to install it, then throws the error. Hopefully thats the problem.Comment
patrickj420
patrickj420
patrickj420
When I manually turn the motor everything turns well, just can't get the motor to turn during sims.Comment
