Toner Coverage (Average, %)
  • Prodigal Son
    • Mar 2009
    • 161
    Oh sorry I didn't see the reply...
    The formula I use is as follows:
    The number of pages for the first coverage range * coverage (see example 1) + number of pages for the second coverage range * coverage + next and so on. Divide the sum with the sum of total number of pages, that gives you a "high" average.
    Example 1
    This is what the machine log displays:
    Coverage 0-2%: 5000 pages
    Coverage 3-5%: 15000 pages
    Coverage 6-10%: 6000 pages
    Coverage 11-20%: 2000 pages
    Coverage 21- < : 1000 pages
    (5000 * 2 = 10000) + (15000 * 5 = 75000) + (6000 * 10 = 60000) + (2000 * 20 = 40000) + (1000 * 21 = 21000) = 206000
    206000 / total of 29000 pages = 7,10%
    Now 7,10% is pretty high since we're using the highest percentage in the range, i.e. 6000 * 10 instead of 6, 7, 8 or 9 which is in the same range. This is a worst-case-scenario number. To bring justice into the equation, you need to calculate the lowest possible number as well, which then becomes example 2:
    (5000 * 1 = 5000) + (15000 * 3 = 45000) + (6000 * 6 = 36000) + (2000 * 11 = 22000) + (1000 * 21 = 21000) = 129000
    129000 / total of 29000 pages = 4,45%.
    Then add the two numbers together (7,10 + 4,45 = 11,55) and divide in 2 and you've got yourself 5,775% coverage, which is probably pretty close to the truth.
    Hope that's mathematic enough for ya
    Peace sells, but who's buying?
    • mrwho
      Major Asshole!
      • 4299
      /me head hurts
      Okay, I took note of that. Thanks a lot!
      Mascan42
      Ibid
      • E Winter
        like I said - it doesn't need to be that sketchy and complicated - just take a look at sp 8-921
        you can calculate all values with your cellphone calculator within 2 minutes even if you dropped school after the third grade
        • Prodigal Son
          • Mar 2009
          • 161
          #19
          I've seen that too, but never trust a machine to do a mans job No really, there are actually 3 ways of doing this to be precise. Your way, 8-921, but also 8-601 and mine, 8-861. The results vary a little though, this is an example from our showroom MPC2800:
          BK Y M C
          8-921 4,34% 4,54% 5,28% 7,85%
          8-601 3,70% COLOR=23,23%
          8-861 4,43% 4,69% 5,41% 7,05%
          It seems your way and mine are fairly close to each other Jan Yours might even be even more precise, I must admit, because of the way the machine counts. Rather than within a range like in my example, it shows a total. Great!
          So everyone knows it - Use 8-921 for average toner coverage. Divide the sum of the total percentage with the number of pages for that color and you're done! Thanks Jan!
          • E Winter
            #20
            cheers
            at first I've tried to calculate this more complicated as well
