Ricoh 2022 "Please Wait"
  • copyaction
    • Oct 2007
    • 991
    Replaced HDD and still won't come out of please wait condition
    Has print scan and fax installed, but I had to disconnect the hard drive to just get it running.
    Is there a fix for this?
  • mikadonovan
    • May 2008
    • 2931
    Try downloading the latest firmware.
    NEVER ASSUME ANYTHING
    • copyaction
      • Oct 2007
      • 991
      Unfortunately I have never done that and am not familiar with the procedure.
      Is there a writeup on the procedure and what hardware might be required?
      thanks
      • Polo-022
        • Sep 2007
        • 486
        Replace Controller PWB and Dimm's.
        • category_five
          • 93
          Push on the Ricoh logo of the fax unit's battery daughter board.
          Information is intended for certified service personnel only. Your mileage may vary, see dealer for details.
          • tonerhead
            • Sep 2009
            • 582
            That is an older model, if I remember right you need the pcmcia memory card to update that one. You first load the Ricoh utility for the card on your pc, the utility is a purchase from Ricoh. Once you have the utility, download the firmware and utility puts it on pcmcia card. Machine off....stick in card in controller....turn on....follow prompts on screen.
            I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
            Especially when it comes to sex
            • FASTSTI
              • Sep 2009
              • 29
              Did you remove the fax option and try?
              You just got Pwned by an STI
              Experience Subaru Power
              • copyaction
                • Oct 2007
                • 991
                I think you might be on to something because they called back today and said the fax stopped working.
                • FASTSTI
                  • Sep 2009
                  • 29
                  I had a similar problem at loreal, it turned out to be the fax board was no good so I ordered a repaired one from the R&R list problem has been solved since then.
