MPC2000 SC551
  • CorkyShark
    • 51
    MPC2000 SC551
    Has anyone had a Ricoh MPC2000 with a SC551. I checked the thermistor and the thermostats, they are fine. I am not familiar with the thermopile. Is that like a fuse, how do you check that with a meter? I reset the machine and it came back later in the day. Reset without doing anything and it went down again today. Tomorrow I am replacing the thermistor and the thermopile, but I have my doubts. Has anyone run into this problem?
  • paperclipsandbubblegum
    • Sep 2009
    • 29
    Had one of these last week...cost me 2 recalls but it turned out to be the thermopile. First one of those I've had fail on me. A bit of work to change the sucker to ! Do make sure all firmware is up to date though. Firmware seems to kill lots of odd ducks associated with the MPC series machines.
    • CorkyShark
      • 51
      Thanks for the reply. I am going there first thing this morning; I will let you know how it works out. I will also upgrade the firmware.
      • Llama God
        • Mar 2009
        • 1353
        Don't the lamps blow on these? I've certainly had an MPc2800 which had blown one element on the twin-element lamp and I'm sure that TonerMunkeh told me that these lamps are iffy too.
        Might not be that, but it's probably worth metering them for continuity.
        • CorkyShark
          • 51
          I replaced the thermopile and updated the firmware. It is day 6 and I haven't had another call. Thanks paperclipsandbubblegum
