Ricoh 1224c color blur on leading edge, black copies ok
  • gorme
    • Aug 2025
    Hi, I have a Ricoh 1224c, color copies come out with a blurred or waterfall effect on about the first half inch of the leading edge of the copy, but the black copies are ok. The next 1 1/2 inches roughly of the color copy is slightly discolored and the rest is ok. There is some streaking from the first half inch that goes all the way up the color copy.
  • gorme
    I wonder if it might be this:
    http://www.copytechnet.com/forums/ri...-color-cq.html
    • Jomama46
      • 2900
      print a color test pattern out of memory to separate the optics from the engine. SP5995
      sigpic
      A+; Network +; PDI+
      • gorme
        Thanks, I will try that tomorrow.
        • paperclipsandbubblegum
          • Sep 2009
          • 29
          Replace the transfer clutch pack assy (B051-4807)
          • wings
            • May 2008
            • 12
            replace the 2 black spring clutches in the gearbox assy.
