Does anyone know an alternative to buying extremely expensive colour dev units for the MPC3500/4500 range? Any help would be greatly appreciated.
MPC3500/4500 dev units
Dev units? You mean the PCU unit? The MPC3500 PCU's split in half, you can just order the drum side and the dev side. Black is B223 2042, colours are all B223 2027. Don't try and put non-OEM parts in these things, you'll regret it.It's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it. -
popcorn
We just replace the developer. B230 9640, 9660, 9670, 9680. I've run dev units well over half a million and never had a problem with them.It's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it.Comment
Btw TonerMunkeh, you sure you're up to your nuts in toner, and that you're nuts aren't made of toner..?Peace sells, but who's buying?Comment
popcorn
According to the PM table in the service manual, you need to:
Replace K dev unit at 320k
Replace KCMY drum units at 80k
Replace KCMY DEVELOPER at 160k
Replace KCMY dev. unit entrance mylar at 80k
There is an addition futher in:
*1: The color development units are considered EM parts because the actual life time of the color development units depends on the usage of color ratio.
So no, you don't have to replace the colour dev units at life, only on failure.It's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it.Comment
mpc2500
this machine is almost a million copy around 800thousand,, so far only the cleaning unit of the transfer belt making a dirty background,,and developer never been change untill now,,is there any posible problem we will encounter in the future,, the pcu we change i think 2 times,,Comment
E Winter
If I need to replace just the OPC. I'm always using the black drum unit for all colors. If I need to replace OPC and DV I'm using complete PCUs from the SPC811 series. But usually the DV units and the DV itself is running way over the specs.Comment
