MPC3500/4500 dev units
  • popcorn
    • Jun 2025
    Does anyone know an alternative to buying extremely expensive colour dev units for the MPC3500/4500 range? Any help would be greatly appreciated.
  • TonerMunkeh
    Professional Moron
    • 3865
    Dev units? You mean the PCU unit? The MPC3500 PCU's split in half, you can just order the drum side and the dev side. Black is B223 2042, colours are all B223 2027. Don't try and put non-OEM parts in these things, you'll regret it.
    Hit it.
    • popcorn
      • TonerMunkeh
        Professional Moron
        • 3865
        We just replace the developer. B230 9640, 9660, 9670, 9680. I've run dev units well over half a million and never had a problem with them.
        Hit it.
        • Prodigal Son
          • Mar 2009
          • 161
          No kidding?! Half a million?? PM cycle is 160k, if you can go 500k that's what I call rock n roll... thanks for that!
          Btw TonerMunkeh, you sure you're up to your nuts in toner, and that you're nuts aren't made of toner..?
          Peace sells, but who's buying?
          • popcorn
            Thanks for the advice
            I'll try it and see how things go. Thanks again.
            • TonerMunkeh
              Professional Moron
              • 3865
              According to the PM table in the service manual, you need to:
              Replace K dev unit at 320k
              Replace KCMY drum units at 80k
              Replace KCMY DEVELOPER at 160k
              Replace KCMY dev. unit entrance mylar at 80k
              There is an addition futher in:
              *1: The color development units are considered EM parts because the actual life time of the color development units depends on the usage of color ratio.
              So no, you don't have to replace the colour dev units at life, only on failure.
              Hit it.
              • Prodigal Son
                • Mar 2009
                • 161
                Oh right, I just took that from the top of my head which was wrong. Good to know though, thanks!
                • jordan_23
                  • Oct 2009
                  • 10
                  mpc2500
                  this machine is almost a million copy around 800thousand,, so far only the cleaning unit of the transfer belt making a dirty background,,and developer never been change untill now,,is there any posible problem we will encounter in the future,, the pcu we change i think 2 times,,
                  • zyqwiz
                    • Jun 2009
                    • 333
                    • Prodigal Son
                      • Mar 2009
                      • 161
                      • Fearless V K
                        • 620
                        Have not had to replace developer in any of our units yet.
                        Don't take that toner with me!
                        • E Winter
                          If I need to replace just the OPC. I'm always using the black drum unit for all colors. If I need to replace OPC and DV I'm using complete PCUs from the SPC811 series. But usually the DV units and the DV itself is running way over the specs.
