hey guys, i have a mp 9000, i needed to do a firmware update because it was 14 stages behind. So i Read through TSB 46 and followed ricohs instructios on this, once the engine and system firmware was finished and completed no problem, i shut down and booted up the machine. All that happens is i get the famous "please wait" screen for an endless amount of time and nothing i have tried will get it running. I have booted with doors open, no HDD, no periphials, no nic, etc... I figure i either fried the system card with the update or scrambled the firmware. Perhaps the engine didnt get updated and only the system did. Is there a way to recover back to the last known firmware and hence allow the machine to be bootable again? or do i have to get a new system card?
MP9000
If you upgrade to the new firmware, either install the Engine 1st or do the Engine and system together. If the system is done first the machine will lock out!! and the only way to recover this is to borrow the system card from a machine that hasn't been upgraded, fit it to the dead machine and upgrade the engine firmware. Then swap the system cards back and the machine will boot ok.
When the engine and system firmware are upgraded you will notice that you lose the printer/scanner options so these must also be upgraded to the Pro versions.It's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it.Comment
