Pages lost when using Document Server?
+ More Options
Posts
  • mrwho
    Major Asshole!
    • 4299
    Anyone ever had a problem of lost pages when printing a document from an MFP's Document Server (in this case a 2045e)? The customer said she printed the document fine before, but now the document prints two less sheets from the middle of the document.
    How can this be?
    Mascan42
    Ibid
  • zyqwiz
    • Jun 2009
    • 333
    Originally posted by mrwho
    How can this be?
    Its old so the hard drive is probably knackered.
    • mrwho
      Major Asshole!
      • 4299
      I never thought an HD error could simply cause the disappearance of a couple of pages of a document instead of trashing the entire document file. Anyway, I'll try to replace the HD (if I remember correctly from another post on this forum, I can use an off-the-shelf standard 3.5 40Gb HDD, right? Could it be bigger?) and see how that goes.
      Thanks for the feedback.
      Mascan42
      Ibid
      • Eric1968
        • 2458
        Before you replace the HDD, check the scanner settings. By default the document server deletes the scanned documents after three days. You can turn this option off.
        • iMind
          Vacuum Cleaning Expert
          • Mar 2008
          • 1116
          Ummm, sorry but that sounds surreal as the documents are stored as one file only so if the file is there all the pages should be too. I suggest you store that file and give it a password, then time will tell.
          • ARTHUR1975
            • Mar 2009
            • 21
            Before attending other things, I would rescan the originals first. Maybe the adf might have been fed with papers that were not well aerated wereby several might have been bunched together with only the top one scanned.
            • imaginemoko
              unTrusted Tech
              • Jan 2008
              • 289
              strange... but i guess its a user problem... blaming the machine where its actually there fault to missed something in there paper work. as mention above re scan the file and place a password... good luck.
              fix the customer first then fix the machine... its simple and makes life more easy.
