Im hoping someone can help! We've got a Ricoh 1224C Photocopier and are having problems trying to network it using an ethernet cable. Ive manually entered the IP address on the copier, but the pc doesnt pick up the copier. The message 'check ip address' keeps appearing on the copier.
Would be very grateful if someone could go through the process of setting up the network. The copier comes with scanner, fax and print.
Ive also been told that we might need software. We didnt get a manual nor software with the copier. We are running windows xp
