1224c sc-305
  • SKTeK315
    Walter
    • Jun 2009
    • 142
    1224c sc-305
    Hey everybody. Removed opc master to vac. out due to color bands. Reassembled. At please wait color being adjusted ind. pops sc-305. Retraced my steps. Removed & reinstalled ops master. Inspected corona clng. looks ok. Tried to run corona clng. in simulation mode, it gave an error ind. Please help.
  • Jomama46
    • 2900
    Remove the cleaner motor and manually turn the rod to free it up. Reinstall the motor and check it out.
    sigpic
    A+; Network +; PDI+
    • paperclipsandbubblegum
      • Sep 2009
      • 29
      Hope this helps
      [SC305] - PCU installed with too much force, see TSB-043
      [SC305] - defective PCU
      discharge harness connector #G0705307 plug contacts bent, can be reformed
      B051_043.pdf
      • SKTeK315
        Walter
        • Jun 2009
        • 142
        1224C sc-305
        Thanks. Yes I did try taking clng motor off & advanced the clnr manualy. It didn't move. Just same code. I didn't look at the discharge connect. I'll try
