ricoh 2045 ADF
  • neocozhu
    • Mar 2009
    • 72
    ricoh 2045 ADF
    Adf can not pick up papers,but put the papers inside a little can puck up why?
  • ARTHUR1975
    • Mar 2009
    • 21
    Have not come across this but try to clean the sensors first. You should also check whether the main connector from the adf is well secured.
    • mikadonovan
      • May 2008
      • 2931
      Change the pickup roller, sep belt and reverse roller. A slick sep belt and/or a worn out reverse roller will give misfeed problems. ALso, keep your original stack below the line on the original feed guide.
      NEVER ASSUME ANYTHING
      • imaginemoko
        unTrusted Tech
        • Jan 2008
        • 289
        yeah am thingking also the paper limit that ADF for this model can feed in. maybe too much paper original. but as mention above cleaning the sensor and replacement of pick-up, separation and feed belt....
        fix the customer first then fix the machine... its simple and makes life more easy.
        • aabarnes1
          • Mar 2009
          • 620
          Also check the torque limiter inside tthe reverse roller
          Grant me the serenity to accept the things I cannot change.
          • tonerjock
            Make sure the spring which holds up the pick-up roller is installed correctly
            • Foo
              • Nov 2009
              • 199
              I have run across this issue a couple of times.
              Try standing to the right of the machine and look under
              the ADF cover(while it's closed). See the pickup roller
              sitting under there. Is it sitting level or is it cocked down
              just a little towards the back. If it's not level the black
              plastic assy. that holds the pickup, feed rollers and feed belt
              has been damaged. It usually cracks where the springs push
              against the right feed belt axle. There's a small finger that
              keeps the feed belt axle in place and gets broken when people
              raise the assy. vertical to clean or remove paper then accidently
              shut the lid without laying down it back down first. I keep
              one in the car at all times. I think the same part works starting
              with the Af350 and is still used in the AF3035 series.
              Hope that helps...btw my first post here.
              Jeff / Foo
              • Lagonda
                • Aug 2008
                • 1649
                Check the drive pully on the front end of the Scanning Roller, B541 3351.
                It spins on the shaft and wont push the original through.
