Ricoh Aficio SP C410 DN - set fusing unit error
  • stokay
    • Sep 2025
    I am getting the following error-"set fusing unit correctly" I just changed the thermister due to error code SC545. I have been through the manual and cannot determine how to fix.
  • TonerMunkeh
    Professional Moron
    • 3865
    This printer is designed to take complete fusers as part of a maintenance kit - try that first.
    Hit it.
    • stokay
      Thanks - new fuser solved problem.
      • techspec
        • Dec 2008
        • 128
        I also found that when I changed the fuser with the new one that was supplied with the maintenance kit I got the set fuser error and the easy way around it was to swap the fuser wiring harnesses which was a five minute job.
        Just thought I would post this just in case someone ever has the same issue.
        • TonerMunkeh
          Professional Moron
          • 3865
          In that case you might have had the incorrectc fuser, there are a few models of the Gaia breed and I'm not sure the fusers are interchangeable between them.
          Hit it.
