How to get the DNS IP for a smtp.company.com
  • kayjaig
    • 144
    How to find out DNS ip of a smtp.company.com
    as i setup scan to email, filled in
    SMTP: smtp.company.com
    DNS1: ????
    DNS2 : ????
    Where and how to get these DNS ip address.
    thanks.
  • SCREWTAPE
    DNS1: ????
    DNS2 : ????
    thanks.
    Try doing, IPCONFIG /ALL
    • kayjaig
      • 144
      thanks for fast reply
      correct me if i am wrong,
      by typing the ipconfig/all, it only show the your own network DNS, that will not help to delivery email to the correct destination.
      say for example:
      customer has a website name: Company.com
      and it ip address for that name is : 66.67.68.69
      email address is : info@company.com
      so the smtp for that company is : smtp.company.com
      and DNS for the company will be : ????
      • aaalexxx
        Engineer
        • Jul 2009
        • 51
        ip config /all is for your internal network DNS.
        it's not the smtp.company.com DNS.
        anyway why you need the smtp.company.com DNS?
        in order for you to resolve hostname or scan to email. you just need to ensure you have your internal DNS enter on the M/C.
        if not do a ping to the smtp.company.com & use IP address instead.
        • pLatik
          • 169
          insert this command outside of the internal net of the cliente:
          nslookup -q=ns companydns.com
          or
          Traceroute, Ping, Domain Name Server (DNS) Lookup, WHOIS and choose: DNS Records
          • TheOwl
            • Nov 2008
            • 1732
            Screwape and aaalexxx are right with the DNS details.
            You only need to know your internal network DNS information as it is the job of the DNS server to resolve the IP address of the name.
            • Venom
              Technical/IT Support
              • Nov 2009
              • 765
              if you need SMTP TCP?IP address then ping the smtp server name
              eg: ping smtp10.bellnet.ca
              it may fail but will give you IP address
              IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
              • Fearless V K
                • 620
                I have found it always best to use the IP address of the SMTP server instead of the name. Network-tools.com lets you lookup the IP address if you know the name of the SMTP server, just enter it, then pick the 'Lookup' option, and it will tell you the IP address.
                Don't take that toner with me!
