hi all,
in ricoh afi 350, followed by sc547 pbm, power supply board found defective and same was replaced. after that m/c gave continuous toner sign and was loading toner nonstopping. same cleared using memory clear method and now the rear side of the copies not fused. both hot and pressure rollers are ok physically. even after replacing the entire fusing unit with another for testing, same problem exists. fusing idling is enabled. how this can be rectified?
