Help: Aficio 551
  • nokia88
    • Aug 2009
    • 72
    Help: Aficio 551
    Hi Everybody,
    Aficio 551 simple copy is Ok .But paper jam's usually happened when it has multi copies (the first paper went out, the second paper touch to transfer belt) . Pls.help me...
    Thank you.
  • Jomama46
    • 2900
    switch the exit mode to face up, if no jams occur, replace the clutches in the duplex unit, if they still occur, replace the clutches in the feed sections.
    sigpic
    A+; Network +; PDI+
    • nokia88
      • Aug 2009
      • 72
      thank for your support, but paper jam happened from tray 1; 2 or bypass
      • Jomama46
        • 2900
        Troubleshoot using this method.
        sigpic
        A+; Network +; PDI+
        • nokia88
          • Aug 2009
          • 72
          what's about HDD ? HDD cound be defective ?
          • Jomama46
            • 2900
            Jeepers Pal,
            You know sometimes you just have to troubleshoot the problem rather than just jumping around.
            Just be glad iMind hasn't responded.
            sigpic
            A+; Network +; PDI+
