We have several 3245c models out with the same recurring fault.
After replacing the fuser belt within a couple of weeks the coating on the fuser belt seems to be separating and causing the surface of the belt to wrinkle causing what look like water marks on the copies.
We have tried replacing all of the PM items within the fuser assembly but the problem still returns.
Has anyone else seen this problem and if so have you managed to find a permanent fix????
