Ricoh 4015 black copies
  • tonyadf
    • Jul 2025
    Iv'e got a Ricoh 4015 giving black copies. Optics are ok, i have changed the drum / dev assembly and even the main board. I had a similar problem a while ago with a different machine and that was a bad dev bias connection but it seems ok here.
    Bright ideas welcome
  • copi_40
    • Mar 2006
    • 49
    Complete black ?
    I had once a very strange behavior caused by ozone fan . Also check filter .
    • tonyadf
      ricoh 4015
      Completely black copy, sometimes putting dev on copies
      • Kopyrtek
        Copier Psychologist
        • Jan 2007
        • 407
        Check the 4th and 5th mirror position and also your drum ground.If that doesn't get it,could be the drum unit itself.
        • tonyadf
          Ricoh 4015
          Thanks for your help guys, it was a poor drum earth, everything fine now.
