AF3035
  • Koosie
    • Nov 2008
    • 121
    AF3035
    I have a problem with a AF3035. It jams in the morning, and as usual it never jams when i'm there. Jam code 66 (Duplex exit 1 OFF) and 14 (Duplex exit 3 ON).
    HELP!!
  • spaceman99
    • Jul 2009
    • 174
    here are 5 things that may help you.
    1: take out the cleaning roller from the fuser.
    2: check to see if the Top rear casing has broken on the dulpex vertical path tray.
    3: check to see if the flipper bar on the top of the dulplex has broken the lug off.
    4: replaced pressure roller in fuser as it has gone soft.
    5: Check to see if the paper is damp.
    • Koosie
      • Nov 2008
      • 121
      Thank you, I did not check the pressure roller cleaner. Will check that.
      • RICOHTEC
        • 42
        JAM at fisrt copy at morning
        Remove link cushion in paper separation UNIT2 ( index 9 p54 part manual)from solenoid lever
        the lever of the solenoide remains glued together against the stubborn in ship's apprentice
