i want to change speed 55 copier to 70 copier , please for me. thank you
change speed AF551 -> AF700
I think this is an interesting question. All the PCBs, motors and gears are the same so what gives it the different speed.
I heard that it is programmed in at the factory, but what happens when you change a PCB,HDD or NVRAM? The speed remains the same.
I guess it must be programmed in more than one place and when the NVRAM is replaced it re-programmes itself. So, if you were to replace all the PCBs,HDD and NVRAM, how would the machine know its speed?Comment
The motor speed can be the same, but the time interval between paper feeds is different. The faster machine often feeds its paper at a shorter interval so it prints more sheets per minute. It's programmed somewhere in the machine, and I also don't know where exactly. What I do know is that it's not a matter of something simple as a firmware change.Comment
eraoufi
you must conect 2 wire together .... if you want mor guid contact me agane on eraoufi@yahoo.comComment
eraoufi
find "A293 5140 Connector Board " ( behind of the main board )
ther is a connector with 4 wire ( 3 brown and 1 white )
you shude connect first & second brown wire together
i can send you pictur of this board and connector if you want ....contact with my mail eraoufi@yahoo.com
I guess I will have to make sure I look at this when I next visit these 2 machines.
Thanks for that.Comment
