lanier 5222 jamming
  • ash_572
    • Oct 2008
    • 523
    lanier 5222 jamming
    this machine is just like a ricoh 1022. if i do a single copy it doesnt jam but when i do multiple copies it always jam on the second page. it jams between the registration roller and the pcu turning the paper into paper fans. machines only done about 120k.
  • Eric1968
    • 2458
    I would replace the registration clutch.
    • Herrmann
      • Jan 2006
      • 792
      Try SEF, does it still jam?
      If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
      • Llama God
        • Mar 2009
        • 1353
        It'll either be the reg clutch or the paper is catching the PCU shutter (tear it off).
        Hope this helps!
        • ash_572
          • Oct 2008
          • 523
          its catching at the bottom end of the pcu
          • zyqwiz
            • Jun 2009
            • 333
            I think there's a black mylar on the base edge of the PCU that gets bent
            • ash_572
              • Oct 2008
              • 523
              its catching it on the base of the pcu. not a mylar. its a brand new pcu thats been replaced.
              • ucinn
                • Jun 2009
                • 383
                door
                on the left hand door, there is an actuator that opens the drum shutter, sometimes this will break and cause the drum shutter not to open completely. Check that to insure the shutter is opening completely
                • CableGuy
                  Impulse Drive Engineer
                  • Oct 2008
                  • 417
                  Does it do it from all trays? Is the paper squared up nicely in the tray? Have you checked that the side fences in the tray haven't lost any teeth, i.e. If you open the side fences fully and then push them together, do they both fences move towards each other?
                  I have it on a regular basis where the teeth on the side guides, underneath the metal plate, get boken and everything looks fine, but the paper is sitting too far back in the tray. This causes it to snag on the workings as it passes throught the pcu.... Worth a look.
                  • RicohTech
                    • Oct 2007
                    • 30
                    Fanning copies
                    The drum door is not opening, causing copy to stop and accordian, just saw this happened
                    • spaceman99
                      • Jul 2009
                      • 174
                      Leave open the side door and trick the door switches. Machine should run and you should see if reg roller is turning. Of cause the machine will jam but you will have a better view. I belive may be reg clutch. Try A4r, see if that will feed.
                      Godd Luck
