Aficio 1060
  • ivacopy
    • Oct 2008
    • 46
    Aficio 1060
    Hi
    After replacing a new developer, OPC drum and cleaning blade all over the paper I have developer. All voltage and settings are correct on the display.
  • Polo-022
    • Sep 2007
    • 484
    Developer bias peaks maybe...(Check dev. roller contact).
    Did you clean/replace the charge corotron?
    • Eric1968
      • 2458
      Did you also replace the brush roller? This roller can get completely soaked with toner.
      • Shadow1
        • Sep 2008
        • 1642
        Quenching Lamps. I've damaged them with my vacuum before.
        73 DE W5SSJ
        • razor
          • Oct 2009
          • 30
          Did u have the doctor blade out on the dev? if so did you put it back in the right place?
          • Llama God
            • Mar 2009
            • 1353
            Is it the right developer? Stupid question I know, but it should be B0649640
            • ivacopy
              • Oct 2008
              • 46
              OPC
              After 2 days and many hours, I have changed many boards but at the end I found out that the problem was is new OPC drum (KATUN shit).
              Thanks to all
              • Vulkor
                • Jun 2009
                • 946
                Aye Katun drums. Ruined many a PM for us. We quit using them.
