Aficio 2238c double image on b/w print only.
  • xlbizs
    • Jun 2009
    • 66
    we have the problem with the aficio 2238C b/w print out (Print from PC, Print from Copier Report or copying at b/w mode). those words (full page) look fatter or double. but it look ok in full color mode. pls help. thank you.
  • Ricohslave
    • 27
    This machine uses dual beam writing in b/w mode (single beam in colour mode). The laser pitch has gone out of adjustment.
    Make a note of the LD beam pitch (SP2-109-5 & 6) and then try resetting it to default (SP 2-109-2 & 3) and then re-input the original settings.
    This worked for me after cleaning a laser unit on a DSc445 (J-C2)
    • Vulkor
      • Jun 2009
      • 946
      Interesting to know, thanks
      • xlbizs
        • Jun 2009
        • 66
        Find the SP2-109-5 & 6's value at the list located at the front cover. the SP mode value does not same as the list. try to reset the same value from the list than the b/w print back to normal. thank you for the advice.
