MPC 3500 No Lan Connection
  • imaginemoko
    unTrusted Tech
    • Jan 2008
    • 289
    Hi Guys, any idea for this model having working good for 145K color copies (print and copy) all of a sudden no lan connection.. no light for its lan the tech before me whos n0ow on vacationset up to usb connection it works..... its printing.... then on its user tools you can't see the file transfer and interface settings tab....
    fix the customer first then fix the machine... its simple and makes life more easy.
  • Eric1968
    • 2458
    Looks like your machine doesn't detect the network part of the controller board. I think you have a faulty controller pcb.
    • imaginemoko
      unTrusted Tech
      • Jan 2008
      • 289
      thanks... i thought about it, but my supervisor wants to be more sure about the pcb... am just wait for the pcb to arrive.
      • salesux
        • 12
        Have you tried connecting a laptop to it with a crossover cable?
        • pocket aces
          Ricoh Technician
          • Nov 2008
          • 72
          make sure you didnt change sp5985-001 0=disable 1=enable this turns your nic card on and off. if its a 0 you wont see file transfer tab or interface setings tab just make it a 1 and you will be all set
          • imaginemoko
            unTrusted Tech
            • Jan 2008
            • 289
            yes sir there all ON (1)... NIC and USB....
            as i print the SMC, at ROM No. No String at Netfile, Scanner, WebUaps, Websys, NIB even if i have already upgrade the firmwares. i have'nt try to print on a cross cable cause even the Orange Led won't light up.
            • D_L_P
              Self Employed
              • Oct 2009
              • 1196
              I agree, sounds like a bad controller if the SP mode is ok. It's possible for a storm, or power surge to short out just the Nic part of the PCB. I've seen that on Canon and Fierys.
              • Herrmann
                • Jan 2006
                • 792
                before you change an expensive contoller board, i would suggest you to make a full reset. give it a try
                If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
                • aaalexxx
                  Engineer
                  • Jul 2009
                  • 51
                  plug out the controller board and put it back again?
                  sometimes it's might work.
                  • spaceman99
                    • Jul 2009
                    • 174
                    Hello
                    I had this on a new install. Turned out the Wirless 801.1 .2 was selected on. This disconected the Nic card. In Sp mode under sp5 ???
                    Other then that you may be looking at a new controller. Just a quick minded surgestion, Is there a memory clear for the controller ? Good luck with it.
                    • Vulkor
                      • Jun 2009
                      • 946
                      Yeah you can do a memory clear for the NCS for the machine.
                      SP 5801
                      10 and 11
                      FYI, we had a machine like this recently have its NIC controller die from a power surge through the network. Had it setup to print USB for a long while before we could get the Controller in.
                      • Shadow1
                        • Sep 2008
                        • 1642
                        Replaced 2 controller boards recently for bad nic's, but only one was a similar model - the other was a MP2550
                        73 DE W5SSJ
